Hello BEOworld,
My situation is this. I just got a couple of records and I am definitely on my way to vinyl. I have a BeoCenter 2500 Ouverture. I was looking for record players when I realized that the B&O tables are some of the best tables out there. To start my way into vinyl I went on ebay and started looking for deals. I found a nice Beogram 5005.
Now to my question. As a child born in the digital age I am not well educated on the vinyl option. I know between most amps and record players a preamp is needed. Now the BeoCenter 2500 says: "Beogram LP (RIAA built-in) Via Aux socket"(http://www.beoworld.org/prod_details.asp?pid=394). I am not quite sure whether the RIAA pre-amp is buit into the BeoCenter 2500 or if the Beogram needs a built in RIAA pre-amp. As a 17 year old, price is important to me. The Ouverture is my dads' and if i get a good deal on the BeoGram I don't want to spend hunderts of more on a solid pre-amp.
Do I need a pre-amp and if yes what would you guys suggest?
Also
Is a Beogram 5005 a good way to enter the vinyl world?
Welcome to Beoworld;
the Beogram 5005 does not have a pre-amp of its own so you will need one. Steve at Sounds Heavenly (found at the bottom of the Beoworld pages) sells an RIAA set for just under £60:
http://www.soundsheavenly.co.uk/bando-riaa.htm
His cables are always exceptional and I expect this RIAA will be too as he understands B&O and the systems.
What will make an even bigger difference to how your vinyl sounds will be the cartridge. Old cartridges normally at some stage suffer from suspension failure and sound awful. Don't despair, they can be repaired by Axel at :
http://schallplattennadeln.de/
You may be lucky and the cartridge that comes with the Beogram (if there is one) may be OK for a while.
All the best with vinyl - you'll love it.
Dave.
