Beocenter 9000 - CD Problem
richardsdavies
Posts 3
richardsdavies Posted: Mon, May 5 2014 6:00 PM
New B&O owner, with a slight problem. Been looking through the forums, but can't seem to find a definitive answer, but a few people with the same problem.
Just bought a Beocenter 9000, but the CD isn't working. It opens and closes (seeminly fine), but doesn't play the CD, make a few relay style clicks, twice, and then turns off, exactly the same as this video:
https://www.youtube.com/watch?v=ej0HKAYfzzI
I left a comment on the vid to see if the guy did manage to fix it, but wondered if anyone else had encountered the same problem, and if they managed to fix it?
Any advice much appreciated! Thanks!
auric
Posts 90
auric replied on Mon, May 5 2014 7:41 PM
Send it to B&O in Chicago or an authorized service center and have it fixed. Its the best solution.
Otherwise if you are technically inclined, do a search in the forum. The topic has been covered.
richardsdavies
Posts 3
Hi, could you possibly point me to where this topic is covered? Been looking for a few hours, seen similar posts, but nothing that was resolved in the end?
Page 1 of 1 (3 items) | RSS
