Ok now this might be a silly question but Will a Uk spec Beosound 9000 work abroad ? the power does say 220-230v
BUT
I have sold many overseas and none have moaned would this just plug straight in
Where is "abroad" ?
Beoworld app with direct photo upload and emoticons.
PhilLondon has hit the nail on the head - where abroad?
In the EU, voltage is almost universally 220-203v and it will be OK if it's a UK spec BS9000. It could still also be used in a 110v country with a step-down transformer. This also assumes that it is already a 220v unit. You need to be more specific.
Dave.
Dave Farr:It could still also be used in a 110v country with a step-down transformer.
Step-UP voltage converter if used here in North America, for example.
Quite right - I'm always getting that the wrong way round - 'voltage converter' is a better way of putting it!
