Hi everyone...
Tomorrow a B&O technician is coming to flash my Beovision 10 to the latest version of the software. At the same time I'd like them to update my PUC list.
Have you got any recommendation for a BlueRay player...
It'd like it to be:
- Small so that I can attach it at the back of the TV (with an accessory from STB-Bracket).
- Work well with the Beo4 through the PUC.
- Possibly have some "connected" features such as Spotify, DLNA...
Any suggestion?
P.
Beoworld app with direct photo upload and emoticons.
Oppo 105?
Your answer is on the stbbracket's website, isn't it? Not much choice for players that play in a vertical position.
If you chooce the OPPO, there is no need to go for the 105.
This has additional audio functions etc that normally aren't used because you connect the player to the BV via HDMI.
The 103 will do the job perfect!
If I should answer that question, I would have to know more about the budget of the op.
@Phil - if you haven't decided yet, just let the technician upload some of the most common codes...the more the better.
Millemissen:@Phil - if you haven't decided yet, just let the technician upload some of the most common codes...the more the better.
I think that's what I am going to do. I won't use it much, so I am not looking to spend that much either. It's just so that I don't have to get the technicians to come back later when I buy one.
I used to have a BV7-32 as a main TV, so have a few DVDs.
