So, my son damaged my Mothers Overture doors, and guide rails.
Seemed simple enough to replace so I ordered the bits.
Is there a service manual anywhere that actually shows you how to fit part 3013090 guide rails repair kit?
Have you looked at the service manuals available on Beoworld?
Part 4 of the service manual gives the procedure for replacing the guide rails in section 5.14.
The service manuals are not the equivalent of a Haines car manual. They are really for service engineers from B&O. If you don't feel up to dismantling half of the Ouverture, your best bet is get a B&O tech to do it at a service centre.
Dave.
