Difference Between Mk1 & Mk2 BeoLab 8000 Bass Drive Units
This post has 14 Replies | 2 Followers
Michael Ellis
Cambridge
Posts 34
Michael Ellis Posted: Wed, May 14 2014 8:31 AM
I note from the information BeoLab 8000 | BeoPhile.com
"…The speaker’s technical specifications remained untouched until the MKII version was released in January 2003 (as from serial numbers 16992475) when it was manufactured with newer driver units which delivered extra bass reproduction at low listening levels…"
New style drive units can be seen here:
On ebay drive units can be found:
New style
Old style
My questions are:
  • Are these drive units interchangeable in terms of physical mounting and electrical characteristics?
  • If the Mk 2 drive units were an improved design with better sound, does putting them into a Mk 1 speaker effect an improvement in sound?
  • Has anyone experience of renovating BeoLab 8000s and any useful experience to share?
At present I have some 6000's but occasionally I see some 8000's on ebay for sale with damaged drive units and tatty frets. I'm wondering how difficult it would be to renovate and whether it would be cost effective.
BeoLab 8000 Mk2, CrystalAccoustic BluDAC, Mac Book Pro Retina
SlyParma
Italy
Posts 127
SlyParma replied on Wed, May 14 2014 11:14 AM
MKII, does not mean better than MKI ...
I have 8000. Problem is the size. Even the BeoLab 18 suffer from the same problems as the 8000/8002.
They are beautiful to look at the 8000/beolab 18, prolonged listening is not tiring, but the HI-Fi is another thing.
AdamS
Posts 373
AdamS replied on Wed, May 14 2014 12:59 PM
The changes were more complicated than just a change of drive units from Mk1 to Mk2 as the crossover configuration was also altered and the speakers went from being a kind of 'two and a half' way configuration to two way.
Beocentral summarises it best: http://beocentral.com/beolab8000speaker
As a result, I would have thought that simply changing the drive units from one type to another would be a pointless excercise and very probably make the speakers sound worse!
Michael Ellis
Cambridge
Posts 34
Many thanks for the information. As mentioned my query is sourced not in upgrading an existing 8000 but rather to see whether buying a non-function pair of 8000's and repairing them with parts from ebay is viable. Looks like there may well be some pitfalls though!
Thanks again for the information.
Neil
Posts 9
Neil replied on Wed, May 14 2014 7:05 PM
Adam,
You have confused me with your comments regarding Mk1 to Mk2, as I thought that the change to 2-way configuration was made quite early in the production run of the speakers, (about 1995 according to the serial number quoted) and that the Mk2 came much later.
Perhaps someone could enlighten me further!
Puncher
Durham
Posts 11,729
Puncher replied on Wed, May 14 2014 7:33 PM
Neil:
Adam,
I believe MK2 was around 2003.
Ban boring signatures!
Hubbe
Posts 90
Hubbe replied on Wed, May 14 2014 7:48 PM
I know that B&O did upgrades for customers a few years ago were they modified Mk1 to Mk2. I was once consider it when one of my Mk1 speakers failed and needed repair. In the end I choose not to. The reason why is because I don´t think the difference in sound between Mk1 and Mk2 are that big. I think its better to spend money on a subwoofer if its deeper bass reproduction  you are after.
Michael Ellis
Cambridge
Posts 34
I've not heard a B&O subwoofer but I note that the problem with the bass from my BL6000's is not that it is not loud enough, it's that it is rather uncontrolled and lacking in definition. I'm mystified as to how adding a sub, no matter how great, would solve this lack of definition particularly when you cannot turn down the bass response in the 6000's/8000's.
But as I said, I've not had the pleasure of listening to one in the flesh.
tournedos
Finland
Posts 7,357
tournedos replied on Wed, May 14 2014 8:07 PM
Puncher:
Although I have forgotten most of this, I believe that sounds about correct. Mk.2 got the ABL system, and it was a different change from the "2.5" to two-way configuration. Mine certainly aren't with ABL, and they have the two bass drivers simply in parallel.
I believe I posted the "borderline" serial numbers of different versions somewhere in the archived forum, they are listed in the leaflet that comes with new treble speakers (with the associated protection circuit upgrade).
--mika
Neil
Posts 9
Neil replied on Thu, May 15 2014 10:07 AM
It would appear that the BL8000 has a complex history (not surprising given the long production run) and that it is not simply a case of a Mk1 model and a Mk2.
Going back to the original post, in upgrading a Mk1 version to Mk2 specification, it looks like there is more to it than a simple change of drive units!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, May 15 2014 10:31 AM
I found the old thread:
http://archivedforum2.beoworld.org/forums/t/775.aspx
Take it with a grain of salt. It is based on sources, but... Big Smile
--mika
Neil
Posts 9
Neil replied on Fri, May 16 2014 6:36 PM
Thanks for the link. Interesting.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Fri, Apr 22 2016 10:39 AM
Hi mika,
 I did a quick read through the old post - could you elaborate a bit more on the statement that the Beolab8000 without ABL
Should be the more natural sounding version ?
I don't quite get it ! Also, it seems quite difficult to find a pair with such a 'low' serial number?!
Wonder why that is :-)
Cheers
ALF
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Apr 22 2016 11:32 AM
I have never compared them side by side myself (and doubt I would hear any difference). That statement comes more or less directly from Beocentral:
--mika
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Fri, Apr 22 2016 12:37 PM
Thank you - well received
 Just gone through the article.......interesting though.
Maybe owners of those pairs with responding serial numbers hang on to them for reasons mentioned in the article.
I will continue looking for those  :-)
Cheers
ALF
Page 1 of 1 (15 items) | RSS
DigiCert Secured Site Seal
