Is it possible to use the CD player from a Beocenter as a CD player in an non-B&O set up? If so, how do I go about to do so?
Sorry for my entry level question...... My first B&O product ever just walked in the door...... (I have the speakers, but are interested in using just the CD player.
Best
Jorwed
Easy. The aux connector has a line level output which you can plug into any line level input.
//Bo.A long list...
I have now the right cables/adapters, but still no sound out from the BO 2300? Do I need to anything with the systems settings?
(I have a DIN to RCA adapter in the back and rca to correct input on the receiver. still no sound......)
jorwed
Do you have a din plug to 2 x phono plugs? if so it may be wired for record (input) not playback (output). If you use a din plug to 4 x phono plugs, two of the four phono plugs should work.
Opman
Thx for your reply. My adapter is one I had laying around, so I dont know. I Orderd this one yesterday, is it doable?
http://www.ebay.com/itm/290786140071?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I think Opman is referring to one of these. You'd use the 2 RCA's that output from the 2300.
