I have been offered an Atlona AT H2H-44m HDMI Matrix at a good price, does any one have experience with the matrix?
the specs seem OK as it has HDMI and S/PDIF. I am just worried about it not having an IR matrix, but this can be over come with a separate IR matrix. Also will it cope with different resolution TVs (beovison 10, beovision 6 and AV9000 (with hdmi to scart converter)?
hope some one can advise?
thanks in advance
Toby
badgersurf:Hi, I have been offered an Atlona AT H2H-44m HDMI Matrix at a good price, does any one have experience with the matrix? the specs seem OK as it has HDMI and S/PDIF. I am just worried about it not having an IR matrix, but this can be over come with a separate IR matrix. Also will it cope with different resolution TVs (beovison 10, beovision 6 and AV9000 (with hdmi to scart converter)? hope some one can advise? thanks in advance Toby
StUrrock:love the pro3 4x4 have installed more than 10 this year works brilliantly. all earlier versions avoid like the plague!!
Can't speak specifically for the Atlona AT H2H-44m, sorry I should have been more clear.
In our experience the early 8x8 models had great problems with IR handling.
