Hello,
This may seem dated, but I'm still connecting things to my BV7-40 mkV via the Scart connectors, most notably for SD video distriubution, but also for my Wii.
I use a Composite to Scart connection currently for video distribution. I initially tried a S-Video + L/R to Scart cable, but output was Black & White.
I'm coming back to the question because the Composite is really not that great. Does anyone know what I can send to the BV7 via the Scart :
Another question, the AV2 & AV3 connections have Component video (Y Pb Pr) but digital audio (SPDIF). Is there some obvious way to send analog audio (L/R) as well ?
Thanks for your help !
- Scott
as long as AV2 and AV3 are SCART connectors you always can connect Composite video and Audio to the SCART connector. SPDIF are optional usable. SCART can also be used for S-Video (Y/C) and for R(ed)G(reen)B(lue) both also for audio. Component Inputs are normally RCA connectors in Red,Green and Blue. and are only for video information. You need to use one audio input for the sound of the component source.
Ralph-Marcus
hello,
answer to self :
i assume the s-video to scart is a standard thing, but s-video shows in b&w. seems like something is missing.
has anyone seen this work ? thanks !
- scott
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
When S-Video is conveyed through a SCART connector, the luminance (and sync) are carried on the same pin as would be used for composite video, and the chrominance (colour) signal is carried through the same pin as would be used for the Red signal in an RGB component signal.
Consequently, if an S-Video signal is sent through SCART to a television which does not support S-Video (either at all, or on that particular SCART input), a monochrome picture will result as the chrominance part of the original signal will have been lost (ignored).
It may be worth repeating your tests with each SCART input (if the TV has more than one) as the supported signal types may be different for each.
Kind Regards,
Martin.
Hi, did you ever get a resolution to this question? I currently have a HDMI to SCART converter, but it is fairly rubbish. So am looking to see if S Video would be a better bet.
Thanks, Andrew.
I got S-Video to work over SCART on my BC6 and BC1. I never actually go it to work on my BV7. I would assume that it should have worked and that I was experiencing some sort of hardware issue.
It is probably worth checking that the your converter is generating a signal that your TV can interpret. I had trouble, for example, with a HDMI to Component converter. and my BC1.
Hi Scott,
I tried the s-video last night and while I get a picture it's terrible, and I get black bars on both sides. It's the same picture I get from the HDMI to SCART converter, again with the black bars either side. I find it very frustrating that there seems to be no way round this issue. My Sky box that is connected via SCART and Component, the scart is only for sound and to give a signal to a link TV. The picture is fine on the link TV, so why can I not get a solution that will give me the same quality picture from the MacMini to scart.?
hi andrew,
don't worry, there is a way. :-)
can you tell us more about your system : tv, converter, skybox outputs, ...
it sounds like you want to distribute a tv signal to a link room as well as watch the source in your main room.
tell us everything. ;-)
Ok.... :-)
I've a BV7 Mk2 (no hdmi) and a link BV6
Connected to the BV7 is an early Sky HD box - It's connect via component for the HD and Scart for the sound and signal to the BV6. The picture is great on the BV7 and very acceptable on the link BV6.
The MacMini is connected to the BV7 via DVI to DVI for the picture. I have a display port to hdmi cable, that is then connected into a hdmi to scart converter and from that to the BV7. The audio is coming from the phono on the mac mini into the same scart plug from the converter. The picture on the BV7 is great, but on the link is fairly terrible.
As a test I connected an old laptop with s-video out into the camera connector on the BV7 and the picture was the same terrible quality as i'm getting from the scart converter.
Any thoughts gladly accepted. All the other inputs to the link tv are great, Sky, DTV ( the bv7 has a digital tuner fitted ) and the DVD.
:-D
The only option i've not tried is using the VGA input on the TV, but will that be shared to the link TV?
Or are only scart connectors shared?
Hello again,
So the problem is getting good quality simultaneous output from a mac mini, one SD and one HD.
The trick is to get both signals into the same AV group. You can use any combination of inputs (Scard or not) as long as you can assign them to the same AV Group.If you are getting picture and sound, I assume that this is OK.
The HD signal to the BV7 seems to be OK as well, your question seems to revolve around the MacMini DisplayPort -> HDMI -> Scart. I had some similar problems with an DisplayPort -> HDMI converter and the root cause was that I could not generate a signal that the next converter in the chain could work with easily.
First thing would be to be verify the output from DP with input to HDMI->Scart converter.. If you need detailed control of your displays for the Mac Mini I would suggest SwitchResX.
I suspect that the DP->HDMI cable is not generating a correct signal. If it really is generating a signal that is in the accepted input for the converter then it is time to look at a different or better converter.
Thank you, at last somebody who actually knows what they are on about. How can I check what the DP is outputting? I wish I could find a better converter but there only seem to be versions of the same one. At this stage i'm considering buying a Gen1 AppleTV and using that with the BV6.
As i'm using the MacMini in mirroring mode for the displays, SwitchResX seemed to get a tad confused. But that could also have been the user getting confused.!
Thanks for your help.
Take care, Andrew.
Yeah,
SwitchResX is powerul, but hard to grasp. :-p
The fact that mirroiring is trying to match the resolution of the two displays sounds like a possible source of error. I assume you are creating a 720p50 signal for the HD signal. You need to be sure you DP->HDMI and HDMI->Scart converts can both use 720p50.
I would think they should, but to double-check can you see what happens if the DVI cable is unplugged from MacMini (i.e. no mirroring) and the MacMini is set to output a SD resolution for the BV6.
Thank you for your help with this, i'll have look at it again tonight. What would be causing there to be a black strip on the left and right of the BV6 display? It looks like the picture is slightly compressed.
It's annoying I cannot set both monitors to have different resolutions and still mirror.
I reinstalled SwitchResX, to test things I've mirroring turned off. So when I set the resolution to 1366 x 786 @ 60hz all I get is a blue screen. So something is out of sync. One thing that might be confusing things further is the BV6 is not HD ready. Cycling through the recommended resolutions in SRX gives me a picture, but none of them correctly fit the screen. Any ideas?
Andrew.
I have a SD BC6, so I know what you mean.
I think the BV6 is expecting a 1280*768 image. Try using p50 or p60. If that doesn't work, you could start playing around with interlaced signals.The not-fitting the screen problem could be overscan.
If the BV6 has an option for this managing, you're saved. Otherwise you could sacrifice a little screen rel estate on the BV7 to make a better fir on the BV6. On my BC6, I just live with an image that is slightly cut...
However, this was just a test and we found out what we need to know.
The mirroring seems to be the problem because it is trying to make the resolutions the same. So how to get around that ? I can see three choices :
To be honest, I have no idea is the second option is possible. Options 1 & 3 are similar and both are based on the idea that your converter can take a HD signal and downscale it.
Option 1 seems more robust because it does not use mirroring. You would need a DVI doubler (easy) and a DVI to S-Video downscaler (maybe not so easy). You could also use the MDP-HDMI and then a HDMI->DVI Adaptor plus a HDMI->S-Video downsclaer. This adds an 'extra' box, but they are easier to find.
Option 3 requires the same HDMI-S-Video downsclaler, but more fooling around on the MacMini becuase of the mirroring. This resembles your initial configuration I believe, and it was not working. So either the downscaler is bad or the mirrored output in the Mac is causing the problem.
Can you tell me more about your HDMI-<SVideo downscaler ? We need to be sure it can work.
It's a torturous path... Talk to you soon,
Nope, no joy on the different resolutions. It's all very odd. Overscan is the only way to get it to fill the screen, but then it's bigger than the viewable area. I'm starting to think the converter might be part of the problem, here is the one I bought...
http://www.ebay.co.uk/itm/HDMI-to-SCART-Composite-Video-Converter-Stereo-Audio-Adapter-PS3-SKY-HD-Blu-Ray-/331246225486?hash=item4d1fd0484e
I am a bit late here and off to the pub, Though this may help.
All worked via ML and video distribution to other B&O TV's including Beo4 commands
For the Wii I bought a Wii to SCART cable from eBay.
For the Sky+ box I used a HDMI to DVI-I connecter on the BV7 MKII and ran a HDMI Cable to the BV7. I also ran an optical to coax digital sound connecter. For video distribution on the Sky + box I used composite to a SCART connector supplied by B&O.
I bought an Apple TV Gen 1 with the ATV flash update which allowed colour via the component connection in composite form + the SPDIF to coax connection for sound.
I have the Mac mini in a box, it was too hard.
.... there is some more to the story... I still have an Atlona HDMI switch etc..
Beoaus.
Hi Andrew,
Yes, I suspect your converter as well. The problem is that downscalers are a very mixed lot, and that price is not necessarily a good inicator of performance (i have seen the same box re-branded by atlona for x3 price).
I would look for anyplace you can 'try before you buy' ; maybe amazon where you can return a product as dysfunctional. Or maybe you can borrow a downscaler ...
As I said, I would go with a HDMI based solution as gear is easier to find. If you MacMini is recent enough you can even send audio through the MDP->HDMI cable. A best case scenario would involve a downscaler with HDMI passthrough as it would save you a box.
Passthrough HDMI would go DVI+Audio and Downscaler would go to SCART. I had something very similar running with BY7-40 mkV a few years ago.
Good luck !
I've just found this...
http://www.lindy.co.uk/audio-video-c2/converters-scalers-c105/video-c1511/hdmi-to-cvbs-s-video-stereo-audio-converter-p7356
One question (on top of all the others. ;-) ) With SVideo, i'm guessing it can only be so good, component be a better route? So going from HDMI to component to scart?
Would this work...
http://www.amazon.co.uk/gp/product/B00A8FIQXA/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B00622MA6W&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=0CKQDGX5MKD0WM7KD1BZ#productDetails
to...
http://www.ebay.co.uk/itm/like/310261217241?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
This is going to drive me to drink...
Ok, so... HDMI to Component works a dream. Connected into the BV7 component connections the picture is great. Now for the 'but' So got the component to scart cable... but no picture is coming through the scart connection on either TV....
Any ideas... All I can think of is the box is giving out yPbPr and the tv wants RGB.... ( would help if the yPbPr connectors were not colour coded RGB.!! )
Yes,
This sort of problem has lead me to purchase quite a few bottles of high-quality whisky ! ;-)
I use a Component to Scart RGB and I had to solve two problems that you may be experiencing :
I solved problem one with a box that converts HSync + VSync to ComposteSync. I solved number two by grabbing power from a USB port on MacMini and adding a resistor to get it under 3v.
I highly suspect problem number 2. If this is the case you should get some sort of weird pattern on the TV as it tries to use the Composite Sync as a Composite Video signal. You can also check the specs of your HDMI->RGB to berify that it is generating a CompositeSync, but it probably is.
Good Hunting !
