Bang & Olufsen AV9000 sound problem
AV9000Avant2
Posts 1
AV9000Avant2 Posted: Tue, May 1 2012 1:43 AM
Hello everyone. I've recently bought a B & O AV9000 TV with an intermittent sound problem. Sometimes it works, but usually it doesn't. I believe I've set the sound up correctly, since it sometimes works, but the Control Centre lead into the back of the TV itself seems unreliable. With the lead plugged in, it makes a very, very quiet version of normal volume, when cranked up to the full level 72 reading on the Sound menu, and if I then turn the volume down to a "normal" level of about 30, unplug the lead from the Control Centre socket on the back of the TV and plug it back in enough times, it works, but then, after turning off the TV and not touching the lead, it doesn't work the next time I turn the TV on. Has anyone else experienced the same problem, and do you have any advice? Many thanks, Iain.
Page 1 of 1 (1 items) | RSS
