Using a Beogram CD 4500 with a Beomaster 5500
kingriek
Posts 2
kingriek Posted: Fri, May 23 2014 8:38 PM
I've been using my Beomaster 5500 and Beogram 5500 for awhile now and love it. I recently picked up a Beogram CD 4500 because of its top loading beauty, but now that I've got it hooked into the 5500 via the Dinn CD port, I can't access any of the remote features for the CD player. All I get is a 'No Contact' signal. I'm new to this 'mixing and matching' stuff. Are the two not compatible? Any info would be appreciated. Thanks in advance.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 23 2014 8:49 PM
"No contact" usually points towards a lack of communication between the Beomaster (!) and the Master Control Panel.
Else check if the captured cable from the CD4500 has all seven pins in the plug or only five or six.
kingriek
Posts 2
kingriek replied on Sat, May 24 2014 4:45 AM
Thanks Martin! That's exactly what it was. Added a couple of finishing nails to the dinn to make the connection and voila! super! The original plug only had five pins.
Page 1 of 1 (3 items) | RSS
