Hello,
I need some help with my Beocenter 7002 record player. It was working perfectly until this morning, I lifted the stlus arm on the record player to remove some dust and the arm is now stuck to the right. There feels to be a lot of tension in the arm and pressing the phono or other buttons does not work.
So far I have turned that player off and tried to adjust the counterweight but no luck.
Please can you help?
Richard
