Beomaster 6000 altering signal source levels
thomz
Posts 9
thomz Posted: Sun, May 25 2014 5:13 PM
Hi there:-)
I´m experiencing a rather  significant difference in sound level when switching between FM and PH, FM being significant louder than PH. I guess this issues stems from the fact that FM-sources have increased in level over the years and also that my newly refurbished MMC-3 has a slightly lower output than prior to its restoration.
I wonder where in the circuitry I could alter the levels with the best result, e.g. attenuate FM a bit and corresponding increase the gain on the phono source.
My own idea is to alter the values of the resistors prior to the source select stage. I am considering raising the value of R106/R206 in order to attenuate FM and lowering the value of R108/R208 in order to increase the phono gain.
Any thoughts?
 Best regards Thomas
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, May 26 2014 8:34 AM
Hi Thomas,
No need to do that, output levels are adjustable at the output of the stereo decoder.
Adjust 8R102 and 8R202.
Smile
Jacques
thomz
Posts 9
thomz replied on Mon, May 26 2014 10:27 PM
Hi Jacques
Of course;-) Did not notice those. Thanx a lot for your help:-)
Best regards Thomas
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, May 27 2014 6:06 AM
thomz:
Hi Jacques
Best regards Thomas
You are most welcome!
Jacques
Page 1 of 1 (4 items) | RSS
