Hi everyone, quick question.
If I bought a ml gateway and connected it up to the mast link and registered the devices does the beolink app automatically populate with the available systems or doe the app layout need to be designed etc.
Cheers
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230: does the beolink app automatically populate with the available systems ...
NO - either manually via your PC - or importing a Beo5/6 config file.
