PS3 to turn on Avant
This post has 7 Replies | 0 Followers
CJM1
Posts 91
CJM1 Posted: Tue, May 1 2012 11:14 PM
How do i set up my PS3 to turn on my Avant? As i have seen this done on a video before Smile
Clarke
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Wed, May 2 2012 12:50 PM
Since seeing that video on youtube, i also have wondered how it's done.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, May 2 2012 3:27 PM
A while ago I had a cheap supermarket DVD player connected to my Avant. Switching on the DVD player turned on the Avant, I don't recall doing anything other than assign the scart socket in the set up menu.
I have since replaced the Avant with a BeoVision7 so I can't check it for you.
Opman
ngnear
Posts 245
ngnear replied on Thu, May 3 2012 3:10 PM
I have a Pinnacle ShowCentre attached to the DVD Scart input. When I switch on the ShowCentre my Avant either turns on or changes over to DVD.
I think you must have Scart cables that are fully wired as the signal is transmitted over one of the pins.
Tim
CJM1
Posts 91
CJM1 replied on Thu, May 3 2012 8:28 PM
What do you mean by "fully wired?" does this mean the connector has to have pins in every single hole?
CJM1
Posts 91
ngnear
Posts 245
ngnear replied on Thu, May 3 2012 10:39 PM
Not only all the pins, but the pins should be all be wired through to each other.
Just search for scart connections with your favourite search engine.
Tim
CJM1
Posts 91
CJM1 replied on Sat, May 5 2012 11:44 AM
Thanks Tim! i will have a look
Page 1 of 1 (8 items) | RSS
