Beocenter 7000 flap
This post has 1 Reply | 0 Followers
bigphil
Posts 69
Silver Member
bigphil Posted: Mon, Jun 2 2014 6:39 AM
Hi I've just bought a very nice beocenter 7000, the aluminium flap lifts very slowly I have to lift it by hand really. Is this an easy fix or shall I leave well alone? Cheers Phil.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jun 2 2014 6:50 AM
Welcome to Beoworld !
You can help it up with your hand, nice and easy, that'll be alright but whatever you do, don't force it up or down, the plastic
damper and hinge will break easily !
You can take the lid mech. apart, clean it a bit and put it back together but it's the amount and consistence
of the kilopoise grease used for the damper together with the springs force, that determines the "timing".
It can be difficult to get right, even when all new parts were available.
Nice Beocenter anyways, don't let the collector bug bite you...
Page 1 of 1 (2 items) | RSS
