Does anyone have the plug wiring colours to solder a new plug onto a damaged lead from the rotating stand. It is a 5pin 240 degrees DIN "TYPE" plug with RED, PINK, BLACK, BROWN, YELLOW wires.
Which colour wire to which pin.
The cable has been badly damaged and I need to solder a new plug on with the correct pin allocations.
Ron
Hi, Did you get the information? As i am looking for the same
