ML setup question please help
This post has 9 Replies | 1 Follower
olvisab
Posts 1,391
olvisab Posted: Fri, Jun 6 2014 6:38 PM
Hi
I have just sell my bv 7 40 and since I unplugged it, I cannot hear the n.radio from my beosound 5 into my beolab 3500 in my kitchen.
Is it a problem of option ?
If it is a problem of option , I have only now a beolink 1000 and I dońt know if I can change the option with it.
I have a mlgw and I cannot control the beosound 5 and the beolab 3500 neither but I believe I have to modify the configuration and remove the bv 7 40.
The mlgw action has been activated into the beomaster 5 too so I should still be able to use it.
Thanks in advance for your help
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab
Posts 1,391
olvisab replied on Fri, Jun 6 2014 8:22 PM
I have seen on beotech the options settings with a beolink 1000. Thanks beotech.
mjmedlo
Posts 922
mjmedlo replied on Fri, Jun 6 2014 11:45 PM
Unplug the gateway and test it out.
Sometimes the gateway confuses the ml network.
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Jun 7 2014 5:22 AM
Try unplugging the 3500, bs5 and mlgw.  Wait a minute or two.  Plug them all back in.
I recently had a problem where my ML network divided.  One side of the house could only work with the tv, the other side only the bs9000/bs5 (each on a different side of the house).  Unplugging everyone, and replugging fixed it.
Stan
Millemissen
Flensborg, Denmark
Posts 14,680
Unplugging/replugging solves most of our problems!
olvisab
Posts 1,391
olvisab replied on Sat, Jun 7 2014 9:53 AM
Hi everybody
Thanks for your advices.
Mjmedlo you are definetely the specialist of the mlgw.
As soon as I have modified the mlgw configuration (delete of the bv 7 entry) everything worked perfectly, even the sound wheel.
olvisab
Posts 1,391
olvisab replied on Sat, Jun 7 2014 10:13 AM
New surprise.
I wanted to modify the sounds settings (bass, highs...) and I discovered that the content of the menu sound has disappeared.
It shows the next menu instead.
I try to restart it.
olvisab
Posts 1,391
olvisab replied on Sat, Jun 7 2014 10:40 AM
A restart solve this problem of menu
I never thought that just unplugged an element of the system could mess up the whole installation.
mjmedlo
Posts 922
mjmedlo replied on Sat, Jun 7 2014 3:28 PM
When you take a master of the ML network it confuses things.
It's usually best if you remove an audio or video master and have the MLGW to unplug the gateway while letting he other pieces reacquaint.
The gateway can hang things up when it has a change up.
Are you using your gateway for any automation?
With a lighting system ??
olvisab
Posts 1,391
olvisab replied on Sat, Jun 7 2014 3:40 PM
Hi
I would love to use it with an home automation system but in France we have not enough choice. Wireless lutron system could be an option but is is not available here.
According to the fact I don't use it enough (only 2 rooms with b&o equipment) , I even wonder if I will keep it
If I keep it I will probably take the control4 way.
Page 1 of 1 (10 items) | RSS
