New Gen Speakers, Optical, would this work
This post has 4 Replies | 3 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sat, Jun 7 2014 11:13 AM
Hi
From what I read of each of the manuals (yes i need a better hobby lol) of the new generation speakers, BL, 17, 18, 20 where they have optical in and optical out (the previous gen may have had this, i'm not sure), would it be possible to connect a television (non B&O) to this and then daisy chain say a couple of speakers ?
If so would this be any benefit to say of having 5 channel sound (if you used 4/5 speakers), or because there is no surround sound decoder, this is sort of null and void?
Thanks in advance
Geoff Martin
Struer, Denmark
Posts 672
This
Aussie Michael:
Although the new BeoLab loudspeakers with Toslink connections are designed so that you can, indeed, daisy-chain your two loudspeakers, the Toslink input accepts PCM S/P-DIF only. This has two implications:
  1. Your source must do the volume regulation (many television brands and models do not volume-regulate their digital outputs- please consult your manual)
  2. No more than 2 channels are available on the Toslink signal. For example, an AC-3 (aka Dolby Digital) or DTS-encoded signal (whether 2.0 or 5.1 channels) will not be decoded by the loudspeakers. I think that, if you do send such a signal, you'll get nothing out of the loudspeaker.
So, you'll still need a surround decoder. And, if you want to use a surround decoder with a digital connection to the loudspeakers, you'll have to find one with digital outputs - although I don't think that such a thing exists due to content protection legalities.
Cheers
- geoff
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks Geoff,
That answers my question
Cheers
Michael.
kai
Posts 362
kai replied on Sat, Jun 7 2014 11:04 PM
Out of interest the new speakers have that but do any of the new beovisions have that connection ??
Millemissen
Flensborg, Denmark
Posts 14,680
Short answer: no!
But they have WiSA, which is a digital (wireless) connection as well.
Page 1 of 1 (5 items) | RSS
