Off button.
BO
Halmstad, Sweden
Posts 728
BO Posted: Sat, Jun 7 2014 12:45 PM
I'm missing the "OFF" button on my Beomaster 3400.
Anyone have a part out unit laying around?
//Bo.
A long list...
the_o_master
Posts 856
Hi BO,
I had a same problem to find OFF button from my Beomaster (I had here a "looking-for" tread too). I couldn't wait anymore and I bought a Beomaster 3400 for the spare parts (unfortunately also with missing OFF), took down an "P5" button and delete the lettering off. Now I have OFF button without any lettering and I think it is better as nothing. Of course, if I would find sometime the original button I will change it.
If you would be also satisfied with this solution, I can send you one of the remaining buttons, which are still predsent on the spare Beomaster. Let me know...
Theomaster
Vintage Bang & Olufsen
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Jun 12 2014 11:49 AM
That is absolutely an option. It is much better than no button at all!
I would very much appreciate if you would like to do that.Smile
//Bo.
A long list...
the_o_master
Posts 856
Yes of course, I can send it to you.
But I forgot one more thing. The OFF button is the only one, which has different bottom side as the others. Others has also a little extension on the bottom and you have to cut it off (with lathe or anyhow) to make it possible to pick it to its place.
Please send me a mail...
Best regards,
Theomaster
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Jun 12 2014 12:28 PM
Mail sent!
The modification shouldn't be any problem.
Thanks!
//Bo.
A long list...
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Jul 13 2014 11:31 AM
Problem solved! Thanks to The O_Master
//Bo.
A long list...
Page 1 of 1 (6 items) | RSS
