Feet for Beogram 4002
This post has 3 Replies | 0 Followers
auric
Posts 90
auric Posted: Mon, Jun 9 2014 8:05 PM
Hi:
I have a BG 4002 Turntable with a missing feet.
The plastic got brittle and broke off.
Does anyone know if this is a standard off the shelf part that purchased? If so who would manufacture it?
Thanks,
Derek
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Jun 9 2014 9:04 PM
Surely I must have these in my dungeon, oops sorry, closet.
Brengen & Ophalen
Menahem Yachad
Jerusalem, Israel
Posts 1,249
These are what I use on all the Beo's which come into my workshop. Not original, but do the damping job a good bit better than the originals.
http://cgi.ebay.com/?ViewItem&item=170413369287
Menahem
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 24 2014 11:23 AM
Black rubber feet leaves black footprints that on some surfaces (f.e. wood) can work into the material and be very difficult
or even impossible to remove.
If I cannot find any original feet, I like to use white felt pads of the selfadhesive type. They come in 3mm thickness which
will also give the correct height of the Beogram.
Page 1 of 1 (4 items) | RSS
