I have configured my beo5 using the config software, but have a few questions.
1) What is the difference between Apple Remote and Apple Remote V.02.30a in the PUC table ? I need to control the black Apple TV 2, which one is the correct one ?
2) When using either of the two PUC codes, I can not use the inner navigation ring on Beo5 and the center go button ? I have to navigate with the outer arrows and play as the go button ?
Appreciate any help on the matter.
