UK to US product help, please?
This post has 10 Replies | 0 Followers
symmes
Posts 247
symmes Posted: Thu, Jun 12 2014 12:42 PM
I was gifted an MX42000 UK and want to use it for simple tasks in US. I bought a 100W step-up converter and connected it per instruction.  Standby light on TV went red, then orange and blew the fuse, twice.  Does that sound more like the wrong strength converter or a possible fault in the TV? Not interested in major investment, but would love to use it to drive some older speakers for Spotify, etc.
Any ideas are appreciated.
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jun 12 2014 3:24 PM
I can't back this up with hard facts concerning the MX4200, but a CRT TV can momentarily use a bit more power when it is starting up. 100W might not be enough for it (it's specified as 56W typical) if it's a hard limit with the converter.
The mains frequency will of course be wrong as well, but I don't think that alone would blow a fuse. B&O TVs usually have a rather extensive self protection circuit, which would shut them down before anything gets that far wrong.
--mika
rxcohen
New York
Posts 201
rxcohen replied on Thu, Jun 12 2014 3:51 PM
A couple of things to look at - you should probably be using a 200W converter (at least 3X the voltage of the product), and check the current limit on the converter.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
symmes
Posts 247
symmes replied on Thu, Jun 12 2014 3:55 PM
I think both you gentlemen nailed me for going cheap on the converter.  Will go to at least 200W and try to hit the current load on the nose.  Thanks.
Marco6474
Posts 54
Marco6474 replied on Thu, Jun 12 2014 4:15 PM
You' d need a more reliable converter, at least three times more powerful than supposed. For a TV, I use one with a regulator which protects your set up.
www.110220volts.com has been a reliable provider.
Hope that heps.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
I recently bought this 300-watt one from B&H Photo for $20.   These things are dirt cheap.
jk1002
Posts 278
jk1002 replied on Thu, Jun 12 2014 9:33 PM
". It is designed for use with appliances or fixtures up to 300W."
There are different types, the way I understood it some are designed for electric shavers, toast ovens, hair dryers and some for electronics. The later being more expensive.
MediaBobNY
Posts 1,106
My 220V BS 3200 & BL 4000 aren't complaining.    Yes - thumbs up
Marco6474
Posts 54
Marco6474 replied on Thu, Jun 12 2014 10:20 PM
When I used a cheap converter with a Beosound 3000 and Beolab 8000, there was a worrying background noise, amplified by the speakers. Is yours working fine for $20?
MediaBobNY
Posts 1,106
MediaBobNY replied on Thu, Jun 12 2014 10:55 PM
Yes.  Here's a closeup of the box.  It states "suitable for appliances OR equpment".   Frankly, I'm amazed at the price - it weighs 7 lbs and is built like a tank.  I suspect if it were made here in the US instead of China it would cost at least $50.
symmes
Posts 247
symmes replied on Fri, Jun 13 2014 12:29 AM
I got the exact same from Amazon for $22 with free 2 day shipping.  I sent the 100W back with no questions asked. Sure hope it works because the MX4200 is perfectly gorgeous and will be paired with set of BL3000 driving a gen 1 ROKU in my wife's office. Thanks for all the great insight.
Page 1 of 1 (11 items) | RSS
