I've just bought Beocenter 2800 and disassembled dust cover, just to clean some corners. And I can't fix it back. The problem is how to place the spring to make it working properly, have been trying numeorus times, checking manuals, web etc, but no effect.
Can somebody help me to fix it up please?
Regards
Ł.
Hi , i have the same problem!!
Hi there,
I had the same problem. These lids are a real pain. Try this, Martin helped me:
http://archivedforum2.beoworld.org/forums/t/11806.aspx
Ben
