Using Beo4 as remote for MacMini
This post has 12 Replies | 1 Follower
steve1977
Posts 911
steve1977 Posted: Sun, Jun 15 2014 3:23 AM
I remember that this is somehow possible. I have my MacMini connected to my BV5 via DVI. How to use the Beo4 remote to control the Mini? Maybe someone can point me to what cable to buy and wat configurations to do.
Thanks in advance!
elephant
AU
Posts 8,219
elephant replied on Sun, Jun 15 2014 4:25 AM
I think it was one or more pieces of software that included CandelAir combined with a PUC which of course translated the Beo4 IR signals (via the BV) into Apple friendly IR signals.  CandelAir (and the other software ?) then allowed the IR commands to trigger various menus.  Without CandelAir (and other?) software all you got was I think (from memory) the iTunes controls that you got in the little Apple remote.
http://www.iospirit.com/labs/candelair/
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Sun, Jun 15 2014 7:31 AM
Thanks for your quick reply. Any idea what cable required? Maybe even a link to this cable?
Simonbeo
Posts 1,451
Simonbeo replied on Sun, Jun 15 2014 9:52 AM
Not totally relevant , but I was surprised to find the Beo4 controlled the iPad when connected by cable to our Beolit12 . Probably totally obvious to many people there's a common language involved.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
steve1977
Posts 911
steve1977 replied on Sun, Jun 15 2014 2:02 PM
Ok, I think I know now what cable is required (http://www.soundsheavenly.co.uk/bando-tvir.htm).
I should have mentioned that I am running Windows on ym MacMini (for reasons not to be discussed in this thread). What software would allows me to map the buttons to control XBMC. I am sure there must be someone with experience in this around this forum?
hfat
Vienna, Austria
Posts 663
hfat replied on Sun, Jun 15 2014 3:27 PM
I use remote buddy to control xbmc on my mac mini. Xbmc is running on osx. If you use windows you might use the microsoft 1039 puc and the corresponding IR receiver (mceusb) to control xbmc.
hfat
Marcello
Posts 213
Marcello replied on Sun, Jun 15 2014 5:02 PM
hfat:
Slightly off-topic, what is the advantage of using remote buddy? I control Plex (which is a heavily customised version of XBMC) without the need of any third-party software.
steve1977
Posts 911
steve1977 replied on Sun, Jun 15 2014 11:41 PM
hfat:
Thanks! Any idea how to the get the microsoft 1039 puc installed or do you expect it may already be installed? How to activate it?
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Jun 16 2014 7:46 PM
Marcello:
I had troubles with some hard wired activation of itunes upon ir commands. Remote buddy offers application profiles for a lot of applications, where you can assign program specific functions to ir commands.
hfat
hfat
Vienna, Austria
Posts 663
hfat replied on Mon, Jun 16 2014 7:48 PM
steve1977:
If you have a BV11 or a V1 you can install your self. Otherwise only your dealer can install the puc
hfat
steve1977
Posts 911
steve1977 replied on Tue, Jun 17 2014 4:48 AM
hfat:
steve1977:
hfat
I have a BV5. How can I find out whether it has already been installed? Is there a menu to select it?
steve1977
Posts 911
steve1977 replied on Sat, Jun 21 2014 4:14 AM
Thanks for your replies. I read from the link that a PUC for Apple Remote is available (Apple TV).
Has someone managed to set this up and can post step-by-step guidelines? How to connect cable? How to select the cable? Just work out of the box then?
Page 1 of 1 (13 items) | RSS
