Beogram 1102
Tonybul
Posts 1
Tonybul Posted: Mon, Jun 16 2014 11:02 AM
hi All, some kid has managed to force the arm of the turntable and has either disconnected or broken the attachment of the "wire" beam that controls the arm  movement to slide mechanism under the white gear control system.....
i have not found any broken bits so i am not sure if it has just diconnected, although i cannot fathom out what it should connect to apart from the slide mechanism thta protrudes through the steel plate [white teflon sleeve with a thin wire shaft protruding from it.
i do have pics, not sure if i can post them?
Page 1 of 1 (1 items) | RSS
