Beolab 3's adding a beolab 2
This post has 7 Replies | 2 Followers
Kirky1980
Posts 30
Kirky1980 Posted: Fri, Jun 20 2014 10:34 PM
Hi all recently bought some beolab 3's and thinking of adding the beolab 2 subwoofer, just wondering how easy these would be to connect to a non b&o television and what cables would be needed
jk1002
Posts 278
jk1002 replied on Fri, Jun 20 2014 11:56 PM
I have that combo with my BS9000 and while some find it too boomy I am loving it.
http://soundsheavenly.co.uk/bando-ipodlab2.htm
The trickyness is that the BL2 needs a current to power on, normally the Beosound or Beovision would supply that when turned on via the powerlink cables.
That cable from soundsheavenly seems to do the trick.
Note that without a BL TV you wont get surround.
Kirky1980
Posts 30
Kirky1980 replied on Sat, Jun 21 2014 9:31 AM
Hi thanks I'm not looking for surround sound really as doing away with surround sound just to have better speakers for music and just wanting them to run through the tv for sound also and will check that cable out thanks and I also don't mind abit of boom ha
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Yes jk1002 has suggested exactly the cable you need (thanks!)!  This connects from the TV headphone socket to the Beolab 2, then you can use Powerlink mk.3 cables from the Beolab 2 to the Beolab 3 speakers: http://www.soundsheavenly.co.uk/bando-pl3.htm
This will give you stereo sound plus bass and will allow the Beolab 2 to manage the bass to the other speakers (as in a B&O setup).  The speakers will remain on (green light showing) while the powered trigger cable is powered up, then they will revert to standby (red light showing) when you power off the trigger cable.
Each speakers also needs its own mains power cable: http://www.soundsheavenly.co.uk/bando-mains.htm
If you need any further help, please feel free to ask!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Kirky1980
Posts 30
Kirky1980 replied on Sun, Jun 22 2014 10:17 AM
Hi thanks for your responses and I have now bought myself a beolab 2 well picking it up next week so does the cable from the tv just need to be one with the 3.5mm jack socket or does it have to have the left and right tac plug also with it as will be ordering all cables needed from yourselves at sounds heavenly as I think you're a wicked place and very helpful with my last purchase, I will be connecting it to a samsung tv and doing away with my 5.1 now as I'm thinking the beolab 3 and 2 are gonna be much better for what I want and loving the bang and olufsen stuff Big Smile
Posts 2,165
Hi Kirky1980,
If you wish to connect the speakers directly to a non-B&O TV (ie. without an AV receiver or pre-amplifier), then you will need to connect the speakers to the headphone (3.5mm) socket on the TV, not the RCA/cinch audio outputs.  This is because the RCA outputs are normally fixed-level outputs, so the speakers would be permanently playing at FULL VOLUME (shouting intended!) Big Smile with no way to reduce the volume.
Only a few older models of Sony TVs, plus certain Loewe TVs have variable volume RCA outputs - to my knowledge no other non-B&O TVs in current or recent production have variable RCA outputs for connecting Beolab speakers.
This will give you stereo sound only, for 5.1 (or higher) surround sound I would recommend adding an AV receiver with pre-out sockets to connect the Beolab speakers to.  If you need any help with cabling for any of these options, please feel free to ask.
Steve.
Kirky1980
Posts 30
Kirky1980 replied on Sun, Jun 22 2014 8:10 PM
Ok thanks Steve and ordered them online just now so look forward to receiving them and getting it up and running Big Smile👍👍👍👍👍👍
Posts 2,165
Many thanks, will email you in a moment - just off to get your cables ready now, will post out in the morning Wink
Steve.
Page 1 of 1 (8 items) | RSS
