Difficulty changing from 4x3 Screen Type
This post has 3 Replies | 0 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Wed, Jun 25 2014 1:54 PM
I can't seem to change from the default 4x3 Screen Type to a 2x3 Screen Type using version 6.0. In the past, it was merely necessary to move all of the existing buttons off of the page so that the page was empty in order to change the screen type. I've tried this, but to no avail. I still have a greyed-out "4x3 Screen Type." Has anyone found a solution to this?
Rivenflush
Gothenburg
Posts 333
You can edit the XML directly, I do not have my computer name but the name of the file is your serial .xml. There is a tag called ScreenType or similar where you set a digit. The number to set is the same as the position in the drop down menu in the tool.
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jun 25 2014 3:19 PM
Thanks for the quick response. However, I would not want to change the screen type for everything. The only screen that I wanted to change from 4x3 to 2x3 is the "Lights" page.
Rivenflush
Gothenburg
Posts 333
Rivenflush replied on Wed, Jun 25 2014 11:26 PM
Actually, the screen type is set individually per screen. I have used this approach myself to change the screen size to 2x3 on the Zones page.
Page 1 of 1 (4 items) | RSS
