Hi, I'm trying to repair a Beogram 1100 turntable. It has no DIN plug so I would like to connect RCA plugs to the cable to connect the Beogram to the preamp (TCC TC 754).
I have the cable/DIN schema (L and R hot, colds and earth) but I don't know how to wire them to RCA plugs... Some help?
Thanks!
Hot L & R to center pin on the RCA, cold L & R to outer ring on RCA, Earth: Chassis BG to earth on TC 754 and to chassis on amp.
Thank you!
Sorry for duplicates, something doesn't work right using the forum with an iPad...
