Beolink convertor 1611 & Sonos
kai
Posts 362
kai Posted: Sun, Jun 29 2014 1:23 AM
I'm sure I asked this in this past but I can't remember is it possible to use convertor 1611 with a Sonos connect amp lined into it and use the command cd or atape to activate passive kits upstairs!
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Jun 30 2014 9:29 AM
I don't know if you asked but also won't try the search function Unsure
1611 can be used to inject an audio signal into a masterlink network, it works as an audiomaster on the masterlink network. To switch to the 'Linein' you should get positive results with a video source.
Ralph-Marcus
Page 1 of 1 (2 items) | RSS
