Cleaning out in boxes, I came across the following items.Some of them I can somehow figure out but it would be nice with exact identifications:
Bag labeled Beosound 9000.
No power supply.
Looks the same at the other end.
Second last picture is wall mounts for BS2300/2500 etc.And the last one is a DIN-extender to be able to extend two cables into one.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
2nd picture:
Spacers for BS9000 to mount a backplate onto the BS9000. Needed for wall mounting.
3rd picture:
AV video expander for MX7000/AV9000. Connected to the AV2 from the BV, it provides extra videoconnections
4th picture:
Wall bracketts for BC2300/2500 and Ouverture.
2nd photo, you show 2 (out of a total of 4) studs that attach to the back of a BS 9000 so you can clip it onto a floor stand. 4th photo - 'handles' - part of wall mount system.
1st picture: feet for Beosystem 3500 / 4500 components
5th picture: powerlink/aux link coupler (to connect two powerlink cables)
Ralf
kallasr:1st picture: feet for Beosystem 3500 / 4500 components
I knew that looked familiar. Used to slant the component forward a bit.
