Beomaster 8000 side/edge panels with veneer
beowolfblue
Posts 2
beowolfblue Posted: Sat, Jul 12 2014 12:25 AM
There have been discussions on removing, transferring or applying new rosewood veneer on the sides of the Beomaster 8000. It looks like the wood veneer is laminated to a plastic panel that may be removable. Does anyone know how to remove the front and side panels? This woud facilitate wood veneer replacement. Thanks
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jul 12 2014 6:02 AM
Open the Beomaster into service position.
The front panel sits with five locking "fingers" and can be twisted off using a small flat bladed screwdriver.
Then the two side panels can be pushed forward a bit and come off too.
Page 7-4 in the service manual.
Edit: And before someone asks; The Beomaster 8000 is the only unit in the 6000/8000 range where the
wooden trim are on separate panels. All other units have the veneer stuck directly onto their plastic chassis'.
beowolfblue
Posts 2
Thanks, Martin! Your always there for B&O users.
Page 1 of 1 (3 items) | RSS
