Installed today the CT6.62 instead of the CT6.00 and no more chrashes while uploading configuration.
Ypeij00: Installed today the CT6.62 instead of the CT6.00 and no more chrashes while uploading configuration.
Hi there
can you share 6.62 as I only have 6.00
Where can I find this?
Eclipse 65V1-32Beosound M5Essence MK2BLI
Please PM me a link?!
+1
Please PM the link also
Who has a link for me?
Would sure like a PM with a link as well.. :)
I PM'd all of you the link to download of the CT6.62.
Greetz,
Dave
To the moderators: If the following does not fit the forum rules, please delete my post.
As many people need help to find the ConfigTool 6.62 , here is the answer:
This was written somewhere in the archived forum but I can't remembre where.
You find the tool in the danish forum beoforum.dk but you must register to see the subforum for the software.
I used google translate to register, but the following is my little HowTo to register for non danish speeking people as I am:
On page www.beoforum.dk click on "Tilmeld" at the bottom left of the page to register.You get to this page : http://beoforum.dk/ucp.php?mode=register&sid=7ee11df3e61071a01191a29ba0a51a19at the upper right select British English in the "Sprog:" field.Click on "I agree to these terms"
You get to this page: http://beoforum.dk/ucp.php?mode=register&change_lang=enFill the needed fields and resolve the "Captcha" question by draging and droping the items to the right column:Disse er kendte Bang & Olufsen udtryk. These are known Bang & Olufsen look.Disse ting er ikke Bang & Olufsen udtryk. These things are not Bang & Olufsen look.submit.When logging in on the Index page, http://beoforum.dk/index.php , on the bottom leftBrugernavn: Username:Kodeord: Password:you will see in the "Beo5, Beo6" Forum a Subforum "Subforum: Konfiguration Software" which isn't displayed when you are not logged in. Here you will find the Config Tool in different versions.
Hope this helps
Good Luck
gerard
Hello all
I upgraded to 6.62 and since then I get the login page which I used to just click OK.
Now when I click OK nothing happens does 6.62 need a login ?
Thank you
Hi All
for anyone who would like to know or has the same problem in the future i fixed the issue.
I installed 6.62 over 6.00 and i had both installed, this allowed me to open the program but when clicking OK after clicking offline nothing would happen.
I removed both versions and installed 6.62 and everything is now fine.
Cheers
These instructions don't work anymore
these instructions don't work any longer????
