hi have just got a b&o ouverture system and trying to get the correct speaker cables as on back of system has7/8 din plugs that should go to my speakers can any body help as not sure where to get these cables/ plugs from have a set of BEOVOX c30 speakers
MANY THANKS
Gary
You can't connect passive speakers as your C30's to the Ouverture. Need a MCL2P amp for that.
Brengen & Ophalen
Or better yet, Beolab 2500s
Thanks for your help being told different things can you tell me would BEOLAB 2000 ACTIVE SPEAKERS with a master link lead plug straight in and play being new to the world of B&o any help is great
thanks
sorry to be a pain found a MCL2P on ebay again what cables would I require to plug in to my overture
Bart1
a 5pin DIN to 5pin DIN cable is enough for this purpose. You could also use a original powerlink cable, but this has to be the thick one. The thin powerlink cable won't switch on the MCL2P!.
Ralph-Marcus
