Hi guys,
I am about to move from one appartment to another. This means that my BV11-40 has to be driven 150km in a van and carried up on the 3rd floor in my new place. Do you guys have any recommandations regarding moving a heavy and delicate piece of equipment like the BV 11? I have previously moved a BV8-40 but this was no problem whatsoever due to the "light" weight and the fact that it could be fitted easily within its original packaging. Unfortuneately I do not have the box for the BV11 as the dealer took care of it as the TV was delivered.
The TV is fitted with the easel stand.
Any inputs would be much appreciated :)
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
I would wrap the whole tv in bubble wrap, plus a blanket with a thick duvet layed down in a van if you could get hold of one with it tied down securely. As it really is a fragile and delicate piece of equipment.
and it would be a shame to scratch or chip the tv or frame.
Beoplay A2
I Endorse this,when I moved from uk to canary isles ordered the packaging for my avant tv through my dealer and product arrived safe and sound.
for future moves and no doubt you will you have the correct protection
malcolm welborn
This TV may be vulnerable to flexing if laid flat. If you are transporting it in a van with adequate height the safest thing would be to bubble wrap it and strap it into the van vertically with the TV pointing front to back. That way the glass will be subject to minimum stress and flexing and it will be relatively unaffected by sudden braking.
The original B&O packing holds the TV vertically and protects from side damage by placing the TV diagonally within the box.
Graham
Thank you all for the inputs! I am considering dismounting the easel stand and transporting the TV on its back on a rubber surface wrapped in a soft blanked. Of course making sure that there is no risk of it sliding into anything. I have called my insurance company and they will cover the damage if anything happens during the transport.
Frederik Beoberg: Thank you all for the inputs! I am considering dismounting the easel stand and transporting the TV on its back on a rubber surface wrapped in a soft blanked.
Strap it to the roof of your car? :) Or hold it in place?
A very wise idea...
Frederik Beoberg: Thank you all for the inputs! I am considering dismounting the easel stand and transporting the TV on its back on a rubber surface wrapped in a soft blanked. Of course making sure that there is no risk of it sliding into anything. I have called my insurance company and they will cover the damage if anything happens during the transport.
Seriously, the TV is large and not very stiff and you will minimise the risk of glass breakage by transporting it upright. If in doubt ask your dealer.
Edit
There's a reason why window installers carry their windows vertically in or on their vans.
Again thank you very much for the advises. I will dismount the easel stand and transport the TV upright wrapped in blankets and secured by a strapping belt to the wall of the van. I will call my dealer tomorrow to hear if he has any advices aswell.
