Hello,
Can anyone help! I am fitting new woofer drivers to my Boelab 6000s. They are driven from a Beosound 3200.
I understand that I need to calibrate the speakers to the dB levels on the new drivers. And the attached voltage figure which are supplied with the drivers.
To do this I need to calibrate the output from the 3200 to achieve a 100mA signal by adjusting the volume whilst playing a 1Khz signal believe. Which of the 7 pin power link pins do I use to measure this output?
Any ideas? Hopefully I have the correct plan?
Many thanks for any help. 😄
