I have a Beocom 6000 cordless phone that was given to e as a present. When I plugged into the oulet all it says is OUT OF RANGE. What can I do ? The other phone is working just fine. Thanks
Did you get a BeoLline base station along with the phone and its charger ?
Th BeoLine is the adapter that takes the POTS and transmits it wirelessly (DECT) to the handset.
http://www.beoworld.org/prod_details.asp?pid=788 <== the 6000 handset (and charger)
http://www.beoworld.org/prod_details.asp?pid=908 <== DECT signal repeater
http://www.beoworld.org/prod_details.asp?pid=1235 <== new style base
http://www.beoworld.org/prod_details.asp?pid=1234 <== old style base
BeoNut since '75
Following on from Elephants post, the Beocam 6000 is a cordless phone so exactly what have you plugged intro where? What is your 'other phone'?
'Out of range' is a sign that the phone is too far away from it's allocated base station. Do you have the original base station for the Beocom6000 or have allocated it to a new one?
We need a bit more information to help you.
Do you have a user manual?
Dave.
