Dear members,
is it possible to set a LCS 7000 to option 4? I was reading in the manuals but couldn't find anything. Thanks!
Does anyone have an installation and setting up guide for the LCS 7000 by the way? Or is it on here in the member's section?
Regards,
Kai
Anybody with information on this? Seems to be a tough one since the LCS 7000 is so rare. Even many B&O employees have never seen or heard of this thing.
Nothing special about LCS7000. It comprises an MCL2A relay kit, a modified MCL transceiver - modified housing, looks like an IR eye for a BL-active/passive-
and a charger. LCS7000 is a transceiver that also works as a wallbracket and a charger for BL7000.
Instead of MCL2a you can even add an MCL2 AV. And you can set it to whatever option an MCL will accept.
As said before I highly recommend to look into user/setup manuals for LCS7000/MCL2AV, that can be downloaded here on Beoworld Manuals section.
Stefan
Thanks very much Stefan.
You are one of the few it seems who has actually installed and used the LCS 7000. I've meanwhile had a look at the manuals but nothing beats experience. When you do something for the first time, in most cases it will go wrong. Therefore, I highly appreciate hints from personal experience. Thanks again!
Cheers, Kai
