Hi guys,
I am looking for the best solution for stream music from my Macbook and Android phone through my Beomaster 1000. Hope you can help with:
What would be the best cables for the best sound input?
What is the best wifi port for such a set up?
Thanks,
Jeppe
Use the tape input, and use a cable like this one
If you want to connect to a computer, it depends on the connections available, if RCA jacks for in and out put, use a 5 pin Din to 4 x RCA, you can then also grab your vinyl to your playlists.
