Hi all,
I've seen a lot of posts already regarding the H6. I consider to buy one to leave the rest of family "quiet" sometimes when needed to listen music when no sleep ....
So I'm looking for a good headphone and though about the H6? Wil it be OK on Ouverture old device ?
Best would be to try bu I can't so as usually if some of you had some experience with both devices thanks to share !
Thank you
Franck
Hi Franck
Yes they would work super with the Ouverture! One of B&O's best systems.
Do shop around for the H6 as there are a lot of deals for £179 at the moment. Also do listen to them as they are a little flat and lifeless for some. Great for classical music fans not good for dance/RnB.
Thanks Paul I'm listening both Classical and Jazz, some pop/rock as well.
Hi Franck,
They are probably very well suited to classical and jazz! Have lots of fun :)
