AV9000 SW1.10 ERROR1
Ilyasse
Posts 3
Ilyasse Posted: Fri, Aug 8 2014 6:19 PM
Hello everybody,
I was playing on my ps3 on my tv and afterwards i just turned it of. After a few hours I wanted to turn my AV9000 on and it dit nothing. On the left display it says SW1.10 and on the right one it says ERROR 1.
I tried everything but nothing works. Also the red led lamp doesn't Show anymore. Can somebody help me?
Dave Farr
France
Posts 2,283
Another user had a similar problem.  Cables can become dislodged in daily use - I had an Avant with no sound as the SCART socket was slightly loose.
Read this thread on the same error code:
http://archivedforum2.beoworld.org/forums/p/1070/8866.aspx#8866
Dave.
Ilyasse
Posts 3
Ilyasse replied on Fri, Aug 8 2014 7:26 PM
I already read that post and also checked my cable en it was in the correct socket. But we daily changed the SCART cable of the ps3 with the scart cable of the cable tv because we couldn't change of AV with the remote :/
Dave Farr
France
Posts 2,283
Have you tried disconnecting the AV9000 from the mains, leaving it for a few minutes and the connecting to Mains again?
Are you saying that each time you use the PS3, you connect a SCART lead to the VCR socket or the AV socket and then take it out afterwards?  What is connected where?
Why can't you change the input source via your remote?  Which remote do you have?
Dave.
Page 1 of 1 (4 items) | RSS
