PC + Beosound 9000 ground loop issue [SOLVED]
This post has 2 Replies | 2 Followers
becho4
Posts 34
becho4 Posted: Wed, Aug 13 2014 9:03 PM
I have a ground loop issue producing a humming noise when connecting my laptop to the aux audio input of a beosound 9000 mkIII.
I have read all the guidelines and documentation I could find on the internet but couldn't solve it yet.
I have the beosound 9000, 2xbeolab 1and the PC connected to the same power strip.
The humming noise disappears if I disconnect the laptop from the mains and runs on battery.
I have tried a desktop PC with exactly the same result as with the laptop.
On the other hand if I replace the Beosound 9000 by a Beocenter 3200 the humming noise disappears completely.
Any suggestions?
Do you think it could be something wrong with the Beosound 9000?
TWG
Posts 1,672
TWG replied on Thu, Aug 14 2014 7:57 AM
I don't think that there's something wrong with your 9000.
An easy solution for fixing ground loop issues is a DI box:
http://www.thomann.de/gb/millenium_dip_passive_di_box.htm
becho4
Posts 34
becho4 replied on Sun, Aug 31 2014 5:33 PM
I finally solved this issue. The aux input cable was defective, just replacing it by a new one solved the problem.
Page 1 of 1 (3 items) | RSS
