Mis-sound from Beogram 1202? how to fix it? (video)
JeppeJensen
Posts 14
JeppeJensen Posted: Thu, Aug 14 2014 11:25 AM
Hey everyone
I have a classic Beogram 1202 and there is a strange 'ticking' sound coming from to upper left corner when I press 'Lift' and it starts turning. I have recorded it on video (28 sec) and would like some help to figure out where this sound comes from and how I can fix it.
Thanks,
Jeppe
Video: https://drive.google.com/file/d/0BzmtvuAeg7B6eFdwdEFJbEg4bjQ/edit?usp=sharing
Format: ???
Duration: Beogram 1202
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Aug 14 2014 3:15 PM
Dirt or damage to the brass motor pulley is my guess.
Maybe a little piece of insulation tape touching the motor anchor.
JeppeJensen
Posts 14
Ok, thanks, Martin. Can I loosen the "shell" and look inside by loosing the screws underneath?
Dillen
Posts 13,191
Dillen replied on Thu, Aug 14 2014 7:06 PM
If that's the black bottom plate, then yes.
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Or the rubber on the flywheel is hardened, and the brass pulley is contacting an irregular spot on the flywheel's rubber.
That requires a rebuild of the flywheel, with new rubber.
Check Terry's Rubber Rollers - I've had a bunch of these redone by him, with excellent results.
Dillen
Posts 13,191
Dillen replied on Tue, Aug 19 2014 7:43 AM
I've used Terry too and can also recommend him.
However, the frequency of the ticking, I think, is consistent with the revolutions of the motor rather
than that of the idler wheel.
Page 1 of 1 (6 items) | RSS
