Beovox CX50 to PC
This post has 6 Replies | 0 Followers
muphlon
Posts 3
muphlon Posted: Fri, Aug 15 2014 4:05 PM
How can I use these on my pc as the main speakers?
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Fri, Aug 15 2014 4:48 PM
All beovox's (unlike beolabs) are passive speakers so you will need an amplifier to power them.
Connect your PCs headphone out to the amps AUX in and you should be good to go.
muphlon
Posts 3
muphlon replied on Sat, Aug 16 2014 9:40 PM
Thanks. What kind of amp are we talking about? I hope something cheap.
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 17 2014 3:34 AM
muphlon:
Look on eBay for the stackables eg 5000 which is we use. Remotes are the real challenge, so the 5500+ gives you a choice of the MCP or a BeoLink 1000, and also positions you for more flexible wiring options
BeoNut since '75
muphlon
Posts 3
muphlon replied on Sun, Aug 17 2014 4:42 PM
Are you talking about this?
Beolab 5000 (1967)
Product : Beolab 5000
Produced from : 1967 - Dec 1972
Designed by : Jacob Jensen
Finish : Rosewood, Teak, (Oak from 1968)
Desirability : 4
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Aug 17 2014 5:14 PM
I think 'Elephant was referring to the Beomaster series.  The Beolab 5000 you have looked at will cost you a lot of money!
The Beomaster 5500 is here:
http://www.beoworld.org/prod_details.asp?pid=354
I don't know if you can just use a headphone amp of some description from your PC headphone out socket?  You just need the correct DIN connectors to the CX50's.  A full Beomaster 5500 or 5000 etc is a good option though so you have better control and ability to expand the system, use the tuner etc.
Dave.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sun, Aug 17 2014 5:16 PM
Have you taken the frets (grills) off those CX50's yet?
A bigger issue is the foam rot of the woofer if they haven't been refoamed yet.
Page 1 of 1 (7 items) | RSS
