LIGHT commands MORNING, TV, LEAVING....are actually FUNCTION_1-10 commands in the MLGW.
I think it's the same in the BLGW. Similiar to commands in CONTROL mode (WINDOW....).
You will find detailed information on the Lintronic site.
http://www.lintronic.dk/AppNote_BEO4_navi.pdf
Stefan
list - settings - advanced - light - show;
then choose your settings
Carolpa:list - settings - advanced - light - show; then choose your settings
mjmedlo: Carolpa: list - settings - advanced - light - show; then choose your settings I have done that but I still can not get te sub menu to pull up under an av command.
list - light - OK - list
does the trick
Carolpa: list - light - OK - list does the trick
I love my Beo4
Millemissen: Carolpa: list - light - OK - list does the trick I love my Beo4 MM
once a One then always a One
and this are not the same commanda as on the Beo4
1: I guess there are pro and cons by the One!
2: No - of course - they are preprogrammed (from the MLGW) and named. A Beo4 only gives you numbers - but it is faster (if you can remember which numbers are which scenes).
Millemissen:1: I guess there are pro and cons by the One! 2: No - of course - they are preprogrammed (from the MLGW) and named. A Beo4 only gives you numbers - but it is faster (if you can remember which numbers are which scenes). MM There is a tv - and there is a BV.
Just got the Beoremote One.
When I choose Light, I can put the light on by pressing the play button, and switch off by pressing pause button.
I can select preset modes by pressing a number.
I can dim by pressing arrows up and down.
But:
Is it possible to configure the presets I have made for my LC2s (1, 2, etc) to eg the preset names like "goodnight" etc in Beoremote One?
Cannot find any options for that.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hello!Anything found yet? I am thinking on buying a LC1 or LC2 and want to control them with the beoremote 1 like using a beo4 - is this conveniently possible?
thanks
Elmar
f5434964: Hello!Anything found yet? I am thinking on buying a LC1 or LC2 and want to control them with the beoremote 1 like using a beo4 - is this conveniently possible? thanks Elmar
Well, not really. I mainly use BR1 to switch my LC2:s on and off, and of course dim. Have problems selecting presets and particular lamps.
but you obviously can switch on/off with BR1?!
How do you add LIGHT to one of the MYButtons?
frog:How do you add LIGHT to one of the MYButtons?
Great! Thanks.
i obviously have no patience as the light button is very far down the list!
