The rear question - recommended speakers
This post has 15 Replies | 0 Followers
rxcohen
New York
Posts 201
rxcohen Posted: Fri, Aug 22 2014 5:07 PM
I am way behind the times and new to surround sound set-ups, so looking for your recommendation and feedback for rear speakers. I am not sure what characteristic of speaker is needed, that would make sense for 5.1 set up, but also could be used for music. My current set-up is BV11-55 ad BL-1s. I have been toying with BL-20s up front, and using BL1 as rears; BL12-3 or !2-2 as rears; BL14; BL17; and adding BL19. Are the new WISA speakers a replacement for 12-2, 12-3 and BL14? Do I need a BL19?
All opinions, recommendations welcome...
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Fri, Aug 22 2014 6:46 PM
If you're looking to get the best solution for the least outlay.. forget acoustic lenses and utilise what you've got.
Keep your BeoLab 1's and buy a BeoLab 2. You've now got the bottom end covered and the BeoLab 1's will give you all the top and mid you'll ever need.
Rear speakers...
In my own personal opinion rear speakers only ever tend to handle echoes, ambient noise and the odd bit of background speech. I think spending too much on surround speakers is a waste of money.
Therefore, 8000's if you like - but 6000's will do it.
If budget is of no consequence, get the 20's at the front and pop some BeoLab 3's at the back. You won't need a subwoofer really. The sound will be crisp, the bass will be precise.
If you want to upgrade and have a mid-level budget - I'd buy some BeoLab 9 for the front and put some BeoLab 3's at the back.  Four acoustic lenses all singing in tune sound wonderful. The BeoLab 9's are now looking great value used and they're overlooked way too much these days.
Only my personal opinion, but I'll put it out there that it's a fairly informed one!
However, we're all different, all hear differently - and all have different acoustic taste...
Lee
pf85
Posts 284
pf85 replied on Fri, Aug 22 2014 6:57 PM
agree with Lee.
I have BL1 in front w/ BL2 and used to have them also as rears. They are now used elsewhere and some used BL3 on floor stands make a lovely addition as rears. I once tested also BL 6000, however through the acoustic lens, the BL3 have a bit more "mid range".
Millemissen
Flensborg, Denmark
Posts 14,680
Agree with Lee.
And - if possible - best try things out at home.
olvisab
Posts 1,391
olvisab replied on Fri, Aug 22 2014 7:39 PM
Bl9 in front or bl20 depending on your budget and bl1 for rears is another solution.
The height of the bl1 is a big advantage if you don't want to fix your rears on your ceiling.
The normal and best placement for rear is on the ceiling in order to reproduce the surround effects.
If by rears you mean "surround speakers" (usual confusion), this placement is not necessary.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen
Flensborg, Denmark
Posts 14,680
@olvisab - ???
If you don't use 'rears' for 'surround speakers' - for what are they then used?
A bit off topic - but anyway.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Aug 22 2014 8:41 PM
9 LEE:
Rear speakers...
I agree with Lee in general. I have BL 1 as front and BL 6000 as rear speakers and I'm nearly happy with this combo since many years, only I missed bass from BL 1. A few months ago I added BL 19 as sub and now I'm absolutely happy. If you like to listen to music seriously, please don't go for a BL 2; it's a 'boom-boom-sub' and only impressive for movies.
Regards
Räuber
olvisab
Posts 1,391
olvisab replied on Fri, Aug 22 2014 8:48 PM
Millemissen:
@olvisab - ???
Rears speakers are for 7.1 setup otherwise you should say surround speakers.
You should know that, your question surprises me, dear MM.
Very few movie score use the rear channels in a 7.1 setup unless the dsp in the amp modify it.
80 percent are for the surrounds speakers.
Millemissen
Flensborg, Denmark
Posts 14,680
Of course I know of that, but in the original posting rxcohen was asking: "that would make sense for 5.1 set up,".
So a 7.1 setup (with rear speakers and surround speakers) was not in the game in this case.
Btw - in the B&O userguides the term 'backs' is used for what you call 'rears'.
"You must select the surround speakers before you can select the back speakers."
rxcohen
New York
Posts 201
rxcohen replied on Sat, Aug 23 2014 6:05 PM
Thank you all for the feedback...I will pop into a store and check the BL19. I am glad to hear it is a good match for the BL1, which are still great but has always missed the bass. As for the surround  I may look at the BL17 later. The wireless capability would be attractive as otherwise in my current room I would be looking at running 9m of cabling on one side. The price though seems a bit steep for the purpose, but will see.
Anyone try the transmitter 1 ? From reading the guide it calls for line of sight. I would prefer to have it behind the BV11-55 hidden.
Razlaw
Posts 4,345
Razlaw replied on Sat, Aug 23 2014 6:57 PM
I highly recommend using the 1s a s rears. I used my 1s as rears with 9s in front and the sound was amazing. Due to decorating decisions the 1s are now fronts in another room with matching 6000s as rears. I very much miss them as rears with my 9s. The height and sound of them are great for use as rears. If I could change my 1s to white, they would immediately return as rears with my 9s.
olvisab
Posts 1,391
olvisab replied on Sat, Aug 23 2014 10:50 PM
Razlaw:
Hi raslaw
I have bl1 at back and plan to buy bl9 in september for front. I hesitate for a pair of bl 5 instead of bl9 but maybe the 9 will be enough.
Did you use a sub with the bl9 and bl1 ?
Razlaw
Posts 4,345
Razlaw replied on Sat, Aug 23 2014 11:01 PM
I tried both with a sub and without. My wife liked it better with the sub. I liked it better without. With a sub the bass is a bit deeper and boomier. Without the sub the base is tighter and more even. I know bass is supposed to be nondirectional but I much prefer the base from the two 9s.
I had 5s brought to my house twice for a demo. I could tell they were different than the 9s but could not say they were better. The 5s certainly are better speaker but in my house, they did not seem better.
olvisab
Posts 1,391
olvisab replied on Sat, Aug 23 2014 11:05 PM
Thanks razlaw for these precision. I suppose you used a bl2. I will try with my bl14 but placed at the back of the room. I will fix the crossover at a very low level in order to use the woofer of the bl9 too.
Razlaw
Posts 4,345
Razlaw replied on Sat, Aug 23 2014 11:33 PM
It was not a BL2 it was a 12 inch Velodyne that we purchased before the BL2 was available.
rxcohen
New York
Posts 201
rxcohen replied on Sun, Aug 24 2014 4:52 AM
Thanks for the feedback Razlaw. I was at B&O today and listened to BL3, BL17, BL18 with/without BL19, BL20 and BL5. I was really surprised with the BL17 + BL19 combination. BL19 made a huge difference. I did not hear a substantial difference between the BL17+BL19 and BL18+BL19. but maybe I need a second listen as there should be. I then compared the BL20 and BL5...and BL20 sounded somewhat muted in comparison. I really cannot recall the BL9 sound, but for music BL5 is superb.
I am somewhat space constraint so probably the BL19 would be a good start. But i am salivating for the BL5s...perhaps eventually.
Page 1 of 1 (16 items) | RSS
