Beovison Avant DVD very loud noise
This post has 1 Reply | 0 Followers
ArcheNoah
Posts 37
ArcheNoah Posted: Sun, Aug 24 2014 6:52 AM
Dear all
My mums good old Avant has a problem.
All began with the clamper of the DVD player which suddenly did not react anymore by pressibg the load button. After some days, I realized a hum comming from the TV in stand by. It sounds like a little electric motor which will only stop when i use the power switch. After that the Avant started like to scream....a very noisy high frequency sound. You won't understand your own words.:-( It stopped once as I pressed the DVD button on the Beo4. But the DVD player does not work any more. There is only a black screen.
i listend carefuly and I found out that it comes from the DVD compartment on top of the TV. But somehow I don't know what can produce such a loud noise in there. Has anybody an idea how I can stop it from doing that?
Thank you for reading and some hints.
Kind regards, Noah.
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Aug 25 2014 9:59 AM
The DVD is a separate module so you could simply disconnect it. Alternatively, get a replacement module and you will have a working DVD again - I must do the same as mine no longer works! I think however my tube is on its last legs so it may be time for a new Beovision!!
Peter
Page 1 of 1 (2 items) | RSS
