Hello All
I am now a proud owner of a Beo6 remote control.
Any advice for a newb with config software etc.
I cannot even get into the setup menu right now on the remote, when i try the screen goes blank.
Eclipse 65V1-32Beosound M5Essence MK2BLI
HI all
Has anyone got the button press guide for SKY HD?
the button presses seem quite different to the Beo4.
If it is a PUC controled function, for example MENU - 2 on Beo 4 , try CNTL_2 (control) in your receiver`s video mode (TV, DTV, V.AUX...whatever).
Stefan
Hi there
Is it normal that after a conifg upload a recharge is always needed?
Yes.
You will find a lot of answers to your questions in the Beo5/6 forum.
