Is there a way to connect a Apple TV 2 to an Beosystem 2?
This post has 9 Replies | 1 Follower
Newbie
Posts 248
Newbie Posted: Tue, Aug 26 2014 9:21 PM
I have an Beovision 4-42 with Beosystem 2 in my office.
Is there a way to connect the Apple tV 2 to this System or is the only way Apple TV 1?
kind regards, Newbie
Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Aug 28 2014 1:03 PM
You can get an HDMI/Composite converter and use one of the scart sockets (theyre on amazon about £20 and work fine) - the PUC should work with Apple TV, if not chose the learn remote command on Apple TV and choose another STB for apple tv to learn
Ryan
Toronto, Canada
Posts 33
Ryan replied on Thu, Aug 28 2014 8:15 PM
Maybe the way to do it is to hook it up the same way a PC would be attached to the system - only the audio (optical out from ATV) goes into beosystem and you cable the ATV directly to the second input on the monitor. Not sure if your monitor has a DVI input or not, if you scour the internet you can even find a HDMI input blade for those panasonic displays.
AMone77
Posts 13
AMone77 replied on Mon, Jan 4 2016 11:19 PM
Hi all Beoworlders!
I have the same Beosystem 2, and as far as I know, my BV4 display has some kind of connection / port under it. (DVI I guess).
Can someone please tell me exactly what kind of cables and/or adapters I need to make my Apple TV (gen. 2 or 3 as far as I know) to work with it? Both picture and sound would be Nice!
(For streaming music and movies and so on from my iPhone and iPad).
Thank you for all help 🙂
mr_anders_son
sweden
Posts 1,710
I use this to my BV7-32 and a BV4-50 at office
But you only get stereosound!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
AMone77
Posts 13
AMone77 replied on Tue, Jan 5 2016 12:37 AM
Thank you Mr. Anderson.
Do you have a name or recomended manufacture for this strange looking item? Works for both picture AND sound?
Any other cables needed?
AMone77
Posts 13
mr_anders_son
sweden
Posts 1,710
http://m.ebay.com/itm/301837191924
http://www.webhallen.com/se-sv/ljud_och_bild/203943-deltaco_hdmi_till_vga-adapter_19-pin_ha-15-pin_ho_1080p_02m?gclid=CISbuKeqksoCFYHVcgodwhwLRg
stampfki
Posts 138
What version of the BS2?
AMone77
Posts 13
AMone77 replied on Wed, Jan 6 2016 11:34 PM
Actually I don't know.
The sticker with the serialnumber is long gone...
Page 1 of 1 (10 items) | RSS
