I`m not quite sure if I understand your question correctly.....
You want to route the sound of your LINK-TV to the BL-passive placed in that link room and control it via your Beo remote, right?
I don`know which TV you have in the link room - assuming it`s a Beovision...:) - but you can connect an audio output of your to the BL active`s PC input.
If you have an ir receiver connected press PC (might be helpful, if you don`t have source PC configured in your Beolink setup) and the BL passive will switch to the local PC input. BL passive should be set to L.OPT 6.
Hope this helps...(???)
Stefan
PS: would be interesting to see if this also can be activated by PC command via ML-/BLGW.....?!
